Activity Forums Adobe After Effects Expressions Solid layer size slider control anchor point movement
  • Solid layer size slider control anchor point movement
    Posted by Obed Ampong on November 11, 2019 at 8:32 pm
    Hello Guys,
    Please, I need help. I am trying to make an animated bar chart data driven by CSV. I have made the bars with a rectangular shape layer. I want to control the y-scale value [1]with slider control. Then I will connect the slider value to CSV via expression. The problem I am facing is the anchor point which controls the length of the bar. I want the bar size to expand from the end only if the value increases, not both ends.
    Thanks in advance.
    Obed
    Obed Ampong replied 6 years, 10 months ago 2 Members · 3 Replies
  • Dan Ebberts
    November 11, 2019 at 9:20 pm
    Can’t you just put the anchor point at the fixed end?
    Dan
  • Obed Ampong
    November 11, 2019 at 9:33 pm
    Please, I tried and still got the same results.
    Regards,
    Obed
  • Obed Ampong
    November 12, 2019 at 5:25 am
    Hello Dan,
    Thanks. I have solved it. I realize that I was scaling the internal rectangular size instead of using transform scale properties.
    Regards,
    Obed
