Activity Forums Adobe After Effects Solid has 2 different colors in comp but the same #color code – looks like a ramp
  • Solid has 2 different colors in comp but the same #color code – looks like a ramp
    Posted by Anilio Sweet on November 3, 2017 at 10:51 am
    Hello Everybody,
    I have a solid with just one color in it. And i copied it so i have 2 solids and a use them to look like widescreen.
    The comp size is 1280 x 720
    For some reasen the solid looks like a ramp, it is brighter on te top tan the bottom.
    I dont know why tis suddenly is? It is wit differnt colors also.
    I have opend a new AE (CS6) project and there is the same problem, also in AE CC 2015
    It is not my monitor, because the client also sees it when i sent te render.
    If i tint the solid and change color it still stays the same.
    And the bright side is alway above in the comp.
    Does anybody knows why this is, and how i can fix it?
    See attachment.
    Thanks in advance
    Anilio
    Anilio Sweet replied 8 years, 8 months ago 4 Members · 5 Replies
  • Cassius Marques
    November 3, 2017 at 11:55 am
    In the first attachment, I see a single orange color.
    Cassius Marques
    http://www.zapfilmes.com
  • Mark Whitney
    November 3, 2017 at 2:17 pm
    What’s your text layer set to for transfer mode?
  • Anilio Sweet
    November 3, 2017 at 2:23 pm
    thanks for reaction.
    there is no transfer mode on the text, and i dont tink that is the issue.
    Beacause, lik mentioned before, i opend a totally new project with only 1 solid in the comp, noting more.
    That is the picure off the full orange
  • Walter Soyka
    November 3, 2017 at 3:38 pm
    The apparent change in the orange solid is an optical illusion, caused by the gradient/shading in the white background.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Anilio Sweet
    November 4, 2017 at 12:30 pm
    Thanks for all the replye’s
    The info pan just shows the same color info numbers top and bottom!
    Concerning the shading and optical illussion, if i chang it to whith without gradient it is still the same.
    And if i change the BG color to black it is still the samen, and this is also with any other bg colors.
    If i chang the color for the top and bottom layrs into antoher color beside organge, you stil see the
    same different that the top is darker than the botom.
    if i use the rectangle tool to mak e a new top and botom i still have the same color issue to.
