Activity › Forums › Apple Motion › Solid color transparency gradient
Posted by Jack Johnson on May 19, 2011 at 6:05 pmIs there a way to apply a transparency gradient to a solid color?
Stephen Smith replied 15 years, 3 months ago 3 Members · 5 Replies -
Mark Spencer
May 19, 2011 at 6:08 pmSure. Just change the fill to Gradient and add and adjust opacity tags.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
https://www.applemotion.net -
Stephen Smith
May 19, 2011 at 6:15 pmYes, Select the Shape. Hit F4 to open up the Shape tab. Under the Style tab change the “Fill Mode from Color to Gradient. Make both gradient colors the same. Above where the two colors are you will see a white square. That represents the opacity. To add another square click anywhere above the white rectangle. Then select one of the squares and changes its opacity. See image below:
Other wise you will have to do a blend mode or Image mask. To learn more about that check out this tutorial on creating a Hologram tutorial
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Motion Tutorials
Stephen Smith
May 19, 2011 at 6:42 pmHappy to help. Best of luck.
Stephen Smith
