Activity › Forums › Maxon Cinema 4D › Solar Flares / plasma energy
Posted by Graham Quince on September 5, 2010 at 1:43 pmHi everyone
I swear I’ve seen a tutorial showing how to create this effect:
If you can’t see it, it’s sort of an aurora borealis effect over a black sphere. Does anyone have either:
a) any idea where the tutorial I think I saw is
b) how I would go about creating this effectThanks in advance,
Graham
http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
Andy Sills replied 10 years, 7 months ago 5 Members · 7 Replies -
Gary Hazen
September 5, 2010 at 9:50 pmTrapcode Flux, for After Effects.
Here’s a tute that will get you started:
https://www.vimeo.com/4151872Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Graham Quince
September 6, 2010 at 9:58 amThanks, I knew I’d seen it somewhere.
After posting, I spent a bit more time in C4D and got quite a good result, although I’m still adjusting the timing for the animation.
I’d love some advice on how to improvement it if anyone has any. I’ve been able to get part of the look using a formula-distortiing sphere with scaled-up Sema noise pattern on the alpha channel.
Graham
Brian Jones
September 6, 2010 at 4:52 pmalways different due to the spectrum captured of course but you look like you are trying for something like this
https://apod.nasa.gov/apod/ap010120.html
your edge flares and prominences are great but I would tighten up the noise in the body of the star a bit.
check out the main archive as well https://apod.nasa.gov/apod/archivepix.html
Graham Quince
September 6, 2010 at 5:42 pmThanks. I’ve managed to due the large prominences manually, but would have preferred an automated solution. I’m thinking of increasing the brightness post-render to enhance it a bit more.
Thanks for the feedback
Jon Simpson
February 12, 2016 at 12:30 amI am not seeing your most recent iteration of this. I just upgraded to 3.5 and am also wanting to create something close to realistic with a sun animation that will morph into a bank logo.
Andy Sills
February 12, 2016 at 2:43 pmThere are ways to do it in c4d, one way would be an emitter with effectors on it. You would need literally millions of nodes to create the effect though, X-Particles for cinema renders a bit faster with your objects but I would still recommend doing it in AE instead of cinema.
If you’re wanting to create the effect in 3d space though, I would set up your scene in c4d with camera animations then use AE to create the effect inside of the effect and use cineware to bring it all together.
Andy Sills
February 12, 2016 at 2:59 pmOH YEAH, tutorial for C4D is here if you’d like.
https://www.youtube.com/watch?v=KVzWJNARkI4#t=1.770305
