Activity › Forums › Apple Final Cut Pro › Software Update
Software Update
Posted by John Davidson on June 24, 2011 at 2:09 amApple recommends all FCPX users run 10.6.8, which just became available this afternoon. If you’re experiencing bugs, let us know if software update fixes them.
Thanks for the forum, too!John Davidson | President / Creative Director | Magic Feather Inc.
Jean-françois Robichaud replied 15 years, 3 months ago 5 Members · 6 Replies -
Craig Seeman
June 24, 2011 at 2:37 amMy recommendation is always do OS updates by using Apple’s Combo Updater and NOT Software Update. The Combo Updater does a much more reliable job of dumping and replacing parts of the OS.
Dale Robinson
June 24, 2011 at 2:42 amCan you please explain Combo Updater, I am not familiar with it. Thanks.
Craig Seeman
June 24, 2011 at 2:53 amSure. Download from here at Apple Support.
https://support.apple.com/kb/DL1399and here’s the explanation but I’ll put it in English
https://support.apple.com/kb/HT4567Delta update is what you get from Software Update and also available from Apple Support. It only updates from the most immediate previous 10.6.x
The problem is I’ve found in some cases when there’s a component name change it leaves the old one behind in addition to the new one. This can create problems. In other cases it seems it may not overwrite a component which can also change problems.Combo Update only available from Apple Support can update from an 10.6.x to the current 10.6.x. I use it even for the most immediate .x update because if there’s any issue with an older component it seems to get rid of it. Basically I’ve found it clears up “odd” inexplicable OS related issues. In fact if you bump into such “odd” behavior even if it looks like it’s specific to an app, using the Combo Update might clear it up. Its about the most thorough thing you can do short of an OS reinstall and it’s a lot easier.
Tony Silanskas
June 24, 2011 at 4:02 amDidn’t realize the Delta issues were still issues. Thanks for the heads up and great little explanation.
tony
John Davidson
June 24, 2011 at 10:01 pmBe advised, our 2.8 Mac Pro has Kona 3 induced kernal panics with 10.6.8. We cannot run drivers at all for Kona with this release. Uninstalled and reinstalled them several times. We were no running the beta Kona software.
Tough decision. Apple says use 10.6.8 for FCPX, but Kona drivers won’t work with it (on our system). Looks like we should have waited.
