Activity Forums DVD Authoring Software to burn BDMV file to disc?
  • Software to burn BDMV file to disc?
    Posted by Cal Knox on May 5, 2021 at 4:40 pm
    I’m just in need of software to burn a BDMV file to a Blu-ray disc, but it’s easier said than done. I’m not having much luck looking around, so I’m asking for recommendations.
    I’ve created a Blu-ray on Encore, but it’s a dual-layered disc so I can’t burn straight from Encore to a BD-50 because there’s some glitch when Encore burns to BD-50s… So I’ve exported a BDMV file/folder plus certificate and just need software to burn it to disc from there.
    FYI: Mac user here.
    I tried Toast Burn from the App Store, but it only authors data discs. I’ve looked at Toast but I can’t find a definitive answer about whether I can burn a BDMV file with the full software. And there are some harsh reviews out there. I don’t want to splash out on software, only to find it doesn’t do the job I need it for.
    Please spare me the “Physical media is dead, don’t bother” or “Don’t use Encore to make a disc”, I really don’t want or need it. The disc is made to my specifications and I’m on the home stretch.
    Thanks in advance.
    Cal Knox replied 5 years, 4 months ago 2 Members · 2 Replies
  • Roman Melekh
    May 5, 2021 at 8:38 pm
    Are you OK to install Windows as a second OS?
    This will allow you to use ImgBurn which is the best free software for DVD/BD build-write.
    It handles break-points on dual-layer disks, can build an image from set of files and burn images also.
  • Cal Knox
    May 6, 2021 at 8:35 am
    Thanks for your reply, Roman!
    ImgBurn sounds like a great option. I have access to PC computers, so I will make my discs with that.
