Activity Forums Compression Techniques Software suggestions for compressing to 4K mp4
  • Software suggestions for compressing to 4K mp4
    Posted by Kevin Cannon on February 7, 2013 at 3:43 am
    I’ve received a request for a set of specs that is pretty new to me, and I’m hoping somebody can shed some light on what software might be able to handle converting to this. Some of the specs (like 60Mbps/60Kbps) seem to exceed the available ranges in Compressor. Some of them (like level and profile) don’t appear to be selectable in Compressor. Any recommended software or approaches to get these exact specs?
    KC
    Resolution: 3840×2160
    Chroma format: 4:2:0
    Sample Depth: 8 bit
    Profile: High (HP) CBR
    Level: 5.1
    Bit rate(VCL): <= 60 Mbps (60 max peak)
    #of ref frame: <= 5 frames
    Frame rate: <= 30p (TV set to 24Hz)
    GOP Size: <= 1 sec
    Entropy Coding: CABAC
    Audio: 384kbps VBR HE-AACv2 5.1ch @96KHz
    Wrapper: MP4
    Color Space
    Rec709 full range 0-255 8bit
    Prehistoric Digital
    Kevin Cannon replied 13 years, 7 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    February 10, 2013 at 8:32 pm
    Either Telestrem Episode or Sorenson Squeeze should be able to handle these. Compressor is great, but not optimized for these outputs.
    Neither has (I believe) a preset for Profile/level – you need to adhere to what those mean.
    Profile is mostly about Color Space
    Level is about Size + Data Rate
    I’d download both, and go at creating a finished file.
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
  • Kevin Cannon
    February 12, 2013 at 3:56 am
    Thanks Jeff, I’ll take a look.
    Cheers,
    KC
    Prehistoric Digital
