Activity Forums DaVinci Resolve Softraid and benchmark
  • Softraid and benchmark
    Posted by Sascha Haber on December 9, 2010 at 7:35 pm
    Hey guys,
    I ,finally, am in the game with my MacPro and I built a little internal software Raid with 4 WD Black Caviars FASS 2 TB each and raided them into Raid 0.
    Then I created some 2K files and let Davinci benchmark the file.
    560 mb/sec !!??
    Can that be possible ?
    I tried a scene detection and it did it almost in double realtime.
    Its…stunning 🙂
    And yes, I only use the GT120 as processing card 😉
    System
    Resolve 7.03
    OSX 10.6
    MacPro late 2010 Dual Westmere 2,4
    6 gig 1033 mhx
    6 TB external eSata hard raid 3, 8 TB internal soft raid 0
    Ati 5770 GUI
    GT120 processing
    Joshua Helling replied 15 years, 9 months ago 7 Members · 15 Replies
  • 15 Replies
  • Darin Wooldridge
    December 9, 2010 at 7:53 pm
    Nice.. What kind of speeds are you getting during playback?
    Looks like I need to do some reading about these drives.
    I’m guessing they are loaded with a cache to achieve that kind of number.
    When trying to playback I’m curious if the loose performance when it caches. (fast, slow, fast, slow)
    Curios about the true sustained speed of the raid. I have found huge peaks and valleys using sata. Thats what pushed me to upgrade to the 32 fibre drives I am currently using for my heavy work. They don’t relay on the cache to give me the high read right numbers.
    Sascha when are you going to hook up a video card so we can see what it can really do??
    Darin Wooldridge
    Colorist / Technical Strategist
    818-653-3918-cell
    dwooldridge@mac.com
    check me out at https://www.facebook.com/pages/Davinci-Resolve-Colorist/117363011609028?ref=….
  • Sascha Haber
    December 9, 2010 at 8:36 pm
    Haha…lets see what Santa has in his big red sack for me 🙂
    I am just grooving in with what i have now.
    Sure the Decklink is next…then the Quadro 4000
    But speaking of benchmarks…
    Has anyone a project loaded with nodes everyone can playback ?
    I would like to toast those 32 Cuda cores in the GT120 for starters.
  • Guilherme Ramalho
    December 9, 2010 at 9:47 pm
    Hi guys,
    My setup:
    Mac Pro 12 core 2,66
    24 Ram
    4 Black-Caviar 2 TB Raid Soft 0
    GT120
    FX4800
    Wave
    The drives rate 539 MB/s !
    I can play 2k dpx with scopes on ! and 5 or even 6 nodes, it starts to get jumpy only with blurs.
    I’m very happy with this performance.
    Gui Ramalho
  • Ron Smith
    December 9, 2010 at 9:54 pm
    My Numbers are similiar in software raid0(striped).
    Does anyone have results in Software raid1(mirrored)??
    Is it the same or less,thinking of going to raid1(mirrored) for backup protection, but curious if I will lose performance .
    Any results would be appreciated.
    thanks
  • Luke Maslen
    December 9, 2010 at 10:55 pm
    Hi Sascha,
    It sounds as though you have a great setup which will make Resolve run beautifully.
    It is quite normal to see outstanding disk performance figures when a disk array is relatively empty. However the real test comes when the disk array is filled to about 80% capacity. You can certainly expect it to slow down significantly by then but, given how fast it is currently running, you’ve clearly got plenty of safety margin and it will continue to run fast even when your disk array is nearly full.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Darin Wooldridge
    December 10, 2010 at 11:44 pm
    Great news!! Are you running in ofp proxy mode or 8 bit mode on your video monitoring to achieve consistent real time 2k with several nodes open.. I just ordered some Black-Caviar to give them as shot.. 🙂
    I to was getting well over 800 MB/s on my home built sata to infiniband raid. I found very inconsitant throughput with high peaks and valleys. It seems I would loose real time playback when the drives cached.. I jumped to fibre and I got the real numbers 400+ mb/s same playback speeds without the slow down every time the drives cached. Another big concern. i have lost several sata drive due to drive failure.. Not a fun situation in raid 0 with clients in the bay.. .
    In short the speed of your raid will go well beyond the speed of the mac resolve.
    One interesting find.. I hit the same exact 2k dpx frames, set the project to sd and i can play at well over 30fps, locked green gpu all day long. Change the setting to 2k or hd and the gpu seems to run out of steam. Green to red on the gpu status bar.. 800+ mb or 400 mb and it runs the same.. No increased performance doubling the speed of the raid.. It did however run much better when I jumped to fibre and got away from the sata drives that rely heavily on the cache to get the high numbers.
    As I see it no matter how fast your raid or drives you will never get the speed to do stereo 2k or even hd with the mac resolve. Linux is still the king using older and slower technology.
    Darin Wooldridge
    818-653-3918-cell
    dwooldridge@mac.com
  • Darin Wooldridge
    December 11, 2010 at 1:35 am
    Another interesting find. If I minimize the application and hit play via the wave. I get much better real time performance. No broken audio playback when reviewing 2k dpx frames with audio in full quality 10 bit.. With the client in the room I minimize the application to help the system run better.
    Maximize the application and it drops down and now audio is popping with inconsistent playback.
    Darin Wooldridge
    818-653-3918-cell
    dwooldridge@mac.com
  • Guilherme Ramalho
    December 11, 2010 at 2:20 pm
    Hi Darin,
    My monitor is set to:
    422 YUV, 10 bit
    But I agree with you, I don’t feel safe with may internal Raid 0… Saving for an external Raid 5.
    Do you have any experience with the Caldigt’s HDPro2 ?
    Gui R.
  • Gary Taylor
    December 12, 2010 at 12:17 am
    Hi Sasha,
    Are you using a card for your external RAID or one of the internal ports looped through the case? This is pretty impressive for sure.
    Thanks in advance,
    Gary
  • Sascha Haber
    December 12, 2010 at 10:18 am
    I am using 4 Western Digital Caviar Black WD2001FASS 2TB 7200 RPM 64MB Cache SATA 3.0Gb/s 3.5″disks internally connected to the 4 ports in the case.
    The system disk resides below the optical drive now.
    I also got me a NewerTech MAXPower eSATA 6G PCIe 2.0 RAID Capable Controller Card sitting in port 3 and I have a Mercury Elite-AL Pro Qx2 #OWCMEQX2T8.0S (4 times WD Caviar green 2 TB ) external case connected to it for backup.
    I use the internal Raid for playback and grading and run Timemachine over night for safety.
    A slice of color…
    DaVinci 7.0.3
    Dual Xeon 2,4
    OSX 10.6.5RAM 6 GB
    RAID 8TB intern
    Extern 6TB
    GTX 285 / GT 120
    WAVE
