Activity › Forums › Apple Final Cut Pro Legacy › Softening Filter for Interviews
Posted by Bill Evelyn on December 18, 2007 at 9:49 pmHello,
I am interested in filters for use in FCP that I can add to headshot interviews of elderly women to gently soften their faces. I want to be subtle about it, not a Barbara Walters effect. What plug-ins do you recommend, or even those available in FCP?
Thanks very much.
Jason Porthouse replied 18 years, 9 months ago 7 Members · 6 Replies -
Brian Pitt
December 18, 2007 at 11:19 pmTry duplicating the video layer and lay it on the track on top of itself. Apply a Gaussian blur to the top track and drop the opacity. Try a couple of different blend modes.
Brian
Arnie Schlissel
December 18, 2007 at 11:44 pmYou might want to try the black/white diffusion in Nattress Film Effects. nattress.com
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Steve Eisen
December 19, 2007 at 12:22 amTiffen dfx (formally 55mm plug-in)
https://www.tiffen.com/dfx_users_gallery_display.htm
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Ben Scott
December 19, 2007 at 12:51 amdo what brain says
“Try duplicating the video layer and lay it on the track on top of itself. Apply a Gaussian blur to the top track and drop the opacity. Try a couple of different blend modes.”
only add in a chroma keyer on that top channel and key out the tonal range or skin chroma with quite a bit of softening
I would say the blend mode to use is soft light or screen with a lower opacity
these commercial plugins are doing exactly the same thing
Max Frank
December 19, 2007 at 2:41 pmUsed correctly, this free filter does WONDERS for interviews!!!!\
https://www.haiku.com.au/2005/08/final-cut-pro-plug-ins.html
Enjoy.
Wayne
Jason Porthouse
December 20, 2007 at 7:06 pmAhhh, stumbled across this eventually, I know I’d seen it somewhere…
https://straylight.tv/pluginz/
and if it works for Lauren Bacall, it’ll work for anyone. Meow.
Jason
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
