Activity Forums Adobe After Effects Soften Edges
  • Soften Edges
    Posted by Eric Klassen on November 18, 2006 at 11:21 pm
    I’ve got about a hundred layers of video that are scaled down and lined up in a circle. I need to soften the edges on these frames so they will blend together better. How do I do this quickly and without creating a huge render situation?
    Eric
    Mike Clasby replied 19 years, 10 months ago 2 Members · 1 Reply
  • Mike Clasby
    November 19, 2006 at 8:27 am
    If the layers are overlapping, have you messed with blending modes? Sometimes a certain blending mode will do just what you want.
    You could select a layer, double the rectangular mask tool, making a mask the size of the layer, then “M” and twirl down to Mask Feather and it seems better if you put a small negative number on Mask Expansion too, then the edges of that layer would be soft. If you only want the vertical edges soft, double click the mask then pull the transform box (like PhotoShop Transform) until the top and bottom of the mask go above and below the layer. Then only the ends will be soft. You could also try roughen edges on each layer.
