Activity Forums DaVinci Resolve Softclip curves weaker in V9
  • Softclip curves weaker in V9
    Posted by Sascha Haber on August 22, 2012 at 11:40 am
    Hi there,
    is it just me or are the Soft Clip curves not as powerful as they used to be ?
    It seems that if I use the gain control the same way as I did in 8, I have much less “power” in the softclips curve to effectively prevent the highlights from clipping.
    A slice of color…
    DaVinci 8.2.1 OSX 10.7.2
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    ICA Instructor
    https://www.icolorist.com/Sascha.html
    Sascha Haber replied 13 years, 12 months ago 6 Members · 9 Replies
  • 9 Replies
  • Rohit Gupta
    August 22, 2012 at 12:06 pm
    Hi Sascha – it should be just the same.
    If you have a project or frame which shows the problem, you know how to reach us!
    Regards,
    Rohit
  • Sascha Haber
    August 22, 2012 at 12:26 pm
    All right, I will make a test and see if I am just blinded by the light 😉
    A slice of color…
    RAID0 8TB
    Extreme 3D+
    ICA Instructor
  • Colin Travers
    August 22, 2012 at 1:32 pm
    I have actually noticed the same thing on this first V9 project I worked on yesterday.
  • Javier Sanchez
    August 22, 2012 at 3:06 pm
    We feel the same, an we use ir a lot.
    Javier Sanchez
    Head Of Technology
    Gama Digital
  • Paul Provost
    August 22, 2012 at 6:16 pm
    weird. just checked and using UI, soft clip at 100 does not do much, but with Tangent Element panel, I can increase soft clip further – but UI stays at 100….
    or am I nuts?
    BTW testing with BMD cinema dng raw files!
  • Margus Voll
    August 23, 2012 at 9:51 am
    It just may be the case that ui is staying on 100 and element can manipulate it more
    as in software it is possible to press it more but ui prevents it.
    Sounds logical software engineering possibility to me.
    Margus
    https://iconstudios.eu
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    Multibridge 2 Pro
  • Sascha Haber
    August 23, 2012 at 10:31 am
    Yes, thats the problem.
    The UI is not going to 100% of the function.
    The Wave can easily double it, that what I am used too.
    Well, I think we found a bug here 🙂
    A slice of color…
    RAID0 8TB
    Extreme 3D+
    ICA Instructor
  • Rohit Gupta
    August 23, 2012 at 10:59 am
    Yup indeed – fix coming in the next update! Thanks all for reporting this.
  • Sascha Haber
    September 3, 2012 at 11:28 am
    Perfect , thanks 🙂
    A slice of color…
    DaVinci 9b3 OSX 10.8
    RAID0 8TB
    Extreme 3D+
    Colorist / Aerial footage nerd
    https://vimeo.com/saschahaber
