Activity Forums Adobe After Effects Soft image render problem
  • Soft image render problem
    Posted by Daniel Garcia robles on January 14, 2011 at 10:16 am
    Hello COW,
    I am having a problem with rendering in the render queue that I have never encountered before.
    I have a 1280×720 square pixels project with a camera move. I have no motion blur in any of the layers or the switch on. The image looks crisp and detailed, but when I render out, the result is always blurred no matter which setting I use. I have tried Quicktime with different codecs and sizes as well as TIFF and Targa sequences but nothing makes the image look as intended and displayed in AE.
    What is going on? Are there any known bugs with version CS4 9.0.3.8?
    Any help very appreciated,
    Daniel
    Petrache Nicolae replied 13 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Michael Szalapski
    January 14, 2011 at 2:37 pm
    You are rendering it out at full resolution, right?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Kevin Camp
    January 14, 2011 at 9:00 pm
    your not rendering with opengl are you? the option is in the render settings from the render queue, click the render settings and make sure ‘use opengl renderer’ is not checked.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Daniel Garcia robles
    January 19, 2011 at 2:24 pm
    First of all, thanks so much for your help and apologies for my delay in replying.
    To: Michael Szalapski:
    Yes Michael, full res.
    To Dave LaRonde:
    That is good to know Dave, actually, the footage is HDCAM, so I guess it should have been ok with it.
    To Kevin Camp:
    I was indeed rendering with OpenGL on, but turning it off didn’t sort out the problem in this instance.
    What I found was that, when switching off the Depth of field setting on the camera, the video would actually render as in the RAM preview. The effect of the depth of field in RAM preview was minimal so I didn’t need it to be on. What I still cannot understand is how the render from the queue was so soft that you couldn’t even distinguish people’s faces. Would the fact that some of these layers had a lens blur effect on the reason for this? Was there some kind of incompatibility between the camera depth of field settings and the usage of lens blur even when the RAM preview was crystal clear??
    Thanks guys,
    Daniel
  • Michael Szalapski
    February 3, 2011 at 7:38 pm
    I know this is an older message, but I’m still curious about it. I can’t replicate the issue you were experiencing. Any chance of a project file (without the footage, of course)?
    – The Great Szalam
    February 3, 2011 at 8:50 pm
    Sure, I still have it. Can I email it to you?
  • Michael Szalapski
    February 3, 2011 at 9:18 pm
    Yup. It’s a Gmail.com address: SZALAMProductions
    – The Great Szalam
  • Petrache Nicolae
    May 24, 2013 at 4:26 pm
    i have the same issue and have found that if i deactivate render with opengl, the project will look perfect. the moment i use opengl, the image is broken.
    any solution to this? i spended 1000$ on an nvidia card wich is supported by adobe for opengl hardware rendering just to end up not using?
    if i use opengl, the project is done in 15 min, if i don’t use opengl (so software mode), the p[roject is done in 2-3 hours?
