Activity › Forums › Apple Final Cut Pro › Soft Focus During Time Lapse
Posted by Ron Fenley, on December 10, 2018 at 9:47 pmFocus on individual frames look great but when played back at normal speed they look slightly blurry.
Ron Fenley, replied 7 years, 7 months ago 4 Members · 8 Replies -
Paul Golden
December 10, 2018 at 10:05 pm1) Are your settings on Better Performance or Better Quality? If It’s Better Performance, then it will be soft during playback and sharp on hold.
2) Did you try rendering out the sequence and re-importing?
Ron Fenley,
December 10, 2018 at 11:23 pmIts set for better quality. You did call it… frame by frame or if I just push the right arrow the focus holds perfect. I hit play and it looks soft even on solid not moving bg shots. Will try to re-import and re-render next. Thank you.
Jeremy Garchow
December 10, 2018 at 11:34 pmBefore Reimporting, try rendering. Select the clips, and hit control-r to “render selection”.
Ron Fenley,
December 11, 2018 at 1:35 amNo it still looks ok. Not as good as some of the stuff I’ve seen on youtube. Especially Griffith the Panasonic GH5 Guy.
Images are there. Just look a little soft compared to each still that I am holding for 1 second. -
Mark Smith
December 11, 2018 at 5:50 pmWhat is the defined frame size of your project? Is the frame size scaled down and is the scale down reduction an integer? Photo stills often have native frame sizes that are not even multiples of video frame sizes – so you could have a photo still that is 4000 px X 3000 px – just picking numbers out of the air. There is no way to reduce that frame size to 1920×1080 by scaling with a whole number factor which results in some interpololation.
Can you do a quick test setting a project to the exact frame dimensions of your stills and see if that makes a difference?
