Activity Forums Maxon Cinema 4D Soft-Bodied Object Melt with Fillet
  • Soft-Bodied Object Melt with Fillet
    Posted by Ángel Molina lópez on April 12, 2019 at 4:26 pm
    Hi everybody:
    I want to create a loop with a couple of cubes but when I add fillet to them and turn them into soft bodies, when they touch the ground, they “melt” like butter. Is there any way to avoid this? I like to round the edges to make it more realistic and that’s why I don’t want to disable it.
    Ángel Molina lópez replied 7 years, 5 months ago 3 Members · 3 Replies
  • Jim Scott
    April 12, 2019 at 5:28 pm
    You need to adjust the soft body settings. Here’s a good tutorial:
    https://greyscalegorilla.com/?s=soft+bodies&post_type=gsg_tutorials
  • Brian Jones
    April 12, 2019 at 8:01 pm
    a possibility is to use a Mesh Deformer to use a simple cube as the deformation cage for the fillet cube, like this
    13262_softbodyfilletviameshdeformer.c4d.zip
    The limitation is the cage needs to be a bit bigger than the target so it depends on your scene. The example file is not a demonstration of how tight it can be and still work, you’d have to play and see.
  • Ángel Molina López Create COW Profile Image
    Ángel Molina lópez
    April 13, 2019 at 3:03 pm
    Thank you for your answers. I’ve also seen that you can use shaders to simulate that the object has rounded edges when it doesn’t really has them. Is there a video that explains how to do that? I can’t find anything.
