Activity Forums Maxon Cinema 4D soda can and tab
  • soda can and tab
    Posted by Joanpablo Torres on December 3, 2013 at 6:49 am
    I purchased a stock can from turbosquid that has the tab and opening rigged to open. It looks great and works great. I have a seperate obj model of a custom tab (oddly shaped) that I need to swap and place into the model and have it animate the same way.
    The problem is I’m totally lost. This can model is inside a hypernurb, a skin and then a bone. I do not use C4D that often and I am not a modeler. C4D is only used when my after effects work calls for it, that’s at what level I am.
    The obj tab is double sided, so one obj for top and another for bottom. I’m hoping I can keep it that way and simply animate them together via a null object.
    I can attach files if need be.
    Joanpablo Torres replied 12 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
