Activity › Forums › Apple Final Cut Pro Legacy › SO? Mixed Formats & Realtime Works?
Posted by Chris Borjis on May 21, 2007 at 8:40 pmAnyone here tried mixed SD/HD and framerates yet all playing
in realtime?Jerry Hofmann replied 19 years, 4 months ago 3 Members · 6 Replies -
Jerry Hofmann
May 21, 2007 at 11:22 pmI have and it’s works OK, but I can definately see a difference in performance with a faster CPU… I’m off to see the Mac man… my dual 2 gig G5 isn’t quite up to what I’d like to see… It’s akin to RT playback of unrendered effects. The faster the machine, the better the experience. Course after you render (and you have to render it eventually) it’s great.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Chris Borjis
May 22, 2007 at 1:46 amNice.
Thanks for the reply Jerry.
What cpu speed is your Dual Core G5?
Chris Borjis
May 22, 2007 at 1:47 amoops, I see you said it was 2ghz.
Does it run “good enough” for editing in your existing system?
I’m going to be running it on a quad core G5 2.5ghz system.
Jerry Hofmann
May 22, 2007 at 2:09 amIt works, I’m impatient though… you[‘ll be just fine! It’s really time for me, the machine is a rev 1 and is about 4 years old now… so I figure it’s time, plus, that octo will be a wonder I think… at least once Leopard comes out and the apps are written to take more advantage of multiple processors.
Jerry
Walter Biscardi
May 22, 2007 at 9:42 am[Jerry Hofmann] “I’m off to see the Mac man… my dual 2 gig G5 isn’t quite up to what I’d like to see..”
Ah but WWDC is just around the corner. Isn’t that where the Mac Pro was first introduced. I’ve been holding off on ordering a Quad Core machine until after this event to see if there will any changes to it.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Jerry Hofmann
May 22, 2007 at 11:50 amI dont’ think we’ll see new towers… they just updated those… we may well see new MacBook Pros though…
Jerry
