Activity › Forums › Boris FX › So where is Boris’s HTML log file located ????
  • So where is Boris’s HTML log file located ????
    Posted by James Richard on May 3, 2011 at 9:54 pm
    I’m using Boris AAF Transfer and I’m not sure where is the HTML log file I searched every where and there is no mentioning about this on the manual as well.
    Can somebody please help???
    Peter Mcauley replied 15 years, 4 months ago 2 Members · 1 Reply
  • Peter Mcauley
    May 4, 2011 at 11:15 am
    I believe that should be located in the same folder as the files that you transferred.
    I hope this helps.
    Cheers,
    Peter.
