Activity Forums Panasonic Cameras So my FS100 doesn
  • So my FS100 doesn
    Posted by Sergio Deustua on January 17, 2007 at 1:05 pm
    Just bought it: FS 100.
    Set it to DVCPRO HD REC and tapeless mode.
    Set my HVX200 to 720/24P and 1394 control BOTH. Firewire connected. Push the REC button in my camera, the FS100 screen changes from the home screen into a newone but before I can reed this new screen the home screen apears again with the word on top: STOP.
    So, what I want to say is that Im not capabile to record anything into the fs100. The manual doesn
    Sergio Deustua replied 19 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Sergio Deustua
    January 17, 2007 at 1:11 pm
    An aclaration:
    The camera is NTSC video standard, and the FS is PAl. Is this a problem when recording in HD? Can this be my problem?. If it is is a big problem.
  • Jerry Zorek
    January 17, 2007 at 3:55 pm
    I don’t believe the HVX200 will send 24p through the firewire port only 60i or 30p. I think you have to record 24p or over/under cranked footage to the P2 card.
  • Jerry Zorek
    January 17, 2007 at 3:58 pm
    Also I don’t believe the PAL version of the FS100 is going to work with the NTSC camera period.
  • Sergio Deustua
    January 17, 2007 at 4:01 pm
    Looks like you are right.
    I find quite hard to beleave that a digital suport like this is is not prepared to work with any frame rate format.
  • Jerry Zorek
    January 17, 2007 at 4:11 pm
    I’m not sure if they crippled this feature by design or if it’s just a limitation of firewire. You could use the 24pA mode I believe and let the camera to the pull down BUT your PAL firestore is still not going to work with the camera. There is a company working on a hard drive that will attach to the P2 slot which should do the trick…if it ever gets released.
  • Barry Green
    January 17, 2007 at 5:31 pm
    The problem is the PAL vs. NTSC units; the FireStore is sold specifically in a PAL-compatible version and an NTSC-compatible version, you have to use the right one with your camera.
    As for the firewire stream: on the US/NTSC version the firewire stream is always 60p (for 720) or 60i (for 1080/480). On the PAL version the firewire stream is always 50p (for 720) or 50i (for 1080/576). Any other frame rate gets embedded within the 50p or 50i data stream, so 720/25p is transported through firewire as 720/50p with each frame being rendered twice.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Sergio Deustua
    January 18, 2007 at 11:03 am
    Thanks. I
