Activity › Forums › Creative Community Conversations › So has the 10.3 Update calmed your fears on the Future of FCPX?
Tony West replied 9 years, 10 months ago 15 Members · 68 Replies
Bill Davis
November 7, 2016 at 9:01 pmThe POINT of Apple is that when things are “in house” they get to cross-pollinate.
As I noted in another thread. Squish down an iPhone into a long thin form-factor and install that along with a subset of it’s code into your keyboard and what do you get?
The TouchBar.
Seems suddenly kinda useful to have FCP X be a healthy subset of Apple as a whole.
Creator of XinTwo – https://www.xintwo.com
The shortest path to FCP X mastery. -
Oliver Peters
November 7, 2016 at 9:16 pm[Bill Davis] “The POINT of Apple is that when things are “in house” they get to cross-pollinate.”
Well, I’ve been told numerous times by folks at ProApps that they don’t get a “heads up” on upcoming hardware. At least not until the last minute. Apple is structured in very tight silos. Obviously this time might be different, but it’s not a given. Otherwise you’d be able to plug your iPhone directly into a new MBP and charge it. ?
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Bill Davis
November 8, 2016 at 12:33 am[Oliver Peters] “Otherwise you’d be able to plug your iPhone directly into a new MBP and charge it. “
You can’t be arguing that won’t happen, can you?
And anyway…
On top power only. Below, Power PLUS very high capacity bi-directional data – making every port a power tap and a connectivity port simultaneously.
This is kinda what manufacturing advancement looks like, isn’t it?.
Just sayin’
Oliver Peters
November 8, 2016 at 12:47 am[Bill Davis] “This is kinda what manufacturing advancement looks like, isn’t it?.”
Except for that MagSafe issue ?
– Oliver
Orlando, FL
Bill Davis
November 8, 2016 at 1:04 am[Oliver Peters] “Except for that MagSafe issue ?”
I’m not sure a problem that can be solved cheaply is really that big a problem.
Oliver Peters
November 8, 2016 at 1:09 amThe moral of the story is to buy stock in adapter companies.
Oliver
Orlando, FL
Andrew Kimery
November 8, 2016 at 2:25 am[Bill Davis] “I’m not sure a problem that can be solved cheaply is really that big a problem.
“I dunno. Add that to the other pile of dongles for the MBP and I think the tally is up to around $250. ?
Speaking of dongles… “Apple’s New USB-C AV Multiport Adapter/Dongle Doesn’t Work”
https://fstoppers.com/gear/apples-new-usb-c-av-multiport-adapterdongle-doesnt-work-152877
Jeremy Garchow
November 8, 2016 at 2:35 am[Oliver Peters] “ell, I’ve been told numerous times by folks at ProApps that they don’t get a “heads up” on upcoming hardware. At least not until the last minute.”
Well, that must have changed, or it’s been a while since you’ve checked in with your sources.
Apple just demoed 3 professional applications all tied to a Touch Bar with on stage demos.
Apple released ProApps software as soon as the last foot left the stage that supported the Touch Bar, and tied the release directly to a MacBook Pro. I don’t know if there could have been any more heads up.
Charlie Austin
November 8, 2016 at 4:52 am[Jeremy Garchow] “Don’t you all think this release was delayed to the release of the MacBook Pro? “
Nope.
~ My FCPX Babbling blog ~
~\”It is a poor craftsman who blames his tools.\”~
~I still need to play Track Tetris sometimes. An old game that you can never win~
~\”The function you just attempted is not yet implemented\”~ -
Charlie Austin
November 8, 2016 at 4:57 am[Oliver Peters] “Since you could already export with roles summed into audio stems shows that this architecture was there, pre-10.3. The need to use compound clips for submixes points to a less-than-adequate approach to solving the problem. “
It’s a lot different under the hood. The fact that it doesn’t appear to be is, in my opinion, why this took so long. I don’t think they’re done, but just guessing…
