Activity Forums VEGAS Pro SO CONFUSED, and i have tried EVERYTHING!!
  • SO CONFUSED, and i have tried EVERYTHING!!
    Posted by Vanny Vanhorn on June 21, 2008 at 4:39 am
    EVERYTHING that i can think of that is! please someone with higher knowledge of Vegas 7.0 plz HELP!!! for some reason my vegas wants to crash whenever i try and render something. it was not like this a week or so ago when i put out another video of mine. but even in the preview in Vegas it seems to “lag” or be very glitchy. THE CATCH IS, it only skips around in about the first HALF of the clips. most of the second half work just find with the preview. but again when i try and render it. it takes FOREVER to get to about 15% and then it just crashes. i am using the DivX codec. i am going to see if i missed an update on it after this. but i couldnt see why that would be the problem.
    PLZ HELP! cheers,
    vannny
    ps: i have been getting an odd error message lately when i boot up saying COM Surrogate has stopped working. its asks me to close it and i do. i looked online and it said it had something to do with my DivX codec saying a possible source of the problem is an outdated version. but it also gave some instuctions on changing the DEP’s (data execution prevention) on my computer i added the rundllhost to the list and it came up on the screen as the COM Surrogate. so i thought HEY I FIXED IT. but then after restarting my computer. Vegas would boot up and without even a heartbeat say it stopped working properly. so i reversed the process and i am basically back at square 1.
    Mike Kujbida replied 18 years, 2 months ago 3 Members · 8 Replies
  • 8 Replies
  • Vanny Vanhorn
    June 21, 2008 at 5:19 am
    i have the most updated version of DivX. i tried to render again just for the fun of it. and it wouldnt even go to 1%. the time just kept going up. 20 minutes later it was at 13 hours. a video of similar format and HALF the time. which last time took 2-3 hours. now i am gettin a lil angry. HELP QUICK before i PUNCH a WALL and break my hand. AGAIN! LOL
    cheers,
    vannny
  • Vanny Vanhorn
    June 21, 2008 at 6:41 am
    i just tried YET again to render after reinstalling DivX. it got to 18% and then said. An Error Has Occured While Rendering. An Exception Has Happened. or something along the lines of that. when the Detail menu is brought down. it says this jibberish.
    Sony Vegas 7.0
    Version 7.0a (Build 115)
    Exception 0xE06D7363 (Unknown Type) IP:0x76FEB08E
    In Module ‘kernel32.dll’ at Address 0x76FD0000 + 0x1B08E
    Thread: ProgMan ID=0xC30 Stack=0x3E2F000-0x3E30000
    Registers:
    EAX=03e2f670 CS=001b EIP=76feb08e EFLGS=00200212
    EBX=002c8800 SS=0023 ESP=03e2f670 EBP=03e2f6c0
    ECX=00000003 DS=0023 ESI=00000000 FS=003b
    EDX=00000000 ES=0023 EDI=6f4d5189 GS=0000
    Bytes at CS:EIP:
    76FEB08E: C9 C2 10 00 89 7D 10 E9 …..}..
    76FEB096: 2D 3D 01 00 90 90 90 90 -=……
    Stack Dump:
    03E2F670: E06D7363
    03E2F674: 00000001
    03E2F678: 00000000
    03E2F67C: 76FEB08E 76FD0000 + 1B08E (kernel32.dll)
    03E2F680: 00000003
    03E2F684: 19930520 19880000 + B0520
    03E2F688: 03E2F708 03D30000 + FF708
    03E2F68C: 6F4D3214 6F4A0000 + 33214 (MFC42.dll)
    03E2F690: 777C162D 77760000 + 6162D (ntdll.dll)
    03E2F694: 00000000
    03E2F698: 0000046E
    03E2F69C: 77768B3F 77760000 + 8B3F (ntdll.dll)
    03E2F6A0: 00000032
    03E2F6A4: 0000005C
    03E2F6A8: 40000000 3FFC0000 + 40000
    03E2F6AC: 400EF87C 400C0000 + 2F87C
    > 03E2F6B8: 00566666 00400000 + 166666 (vegas70.exe)
    > 03E2F6BC: 6F59EA9C 6F4A0000 + FEA9C (MFC42.dll)
    03E2F6C0: 03E2F6F8 03D30000 + FF6F8
    > 03E2F6C4: 76F443CD 76F20000 + 243CD (msvcrt.dll)
    03E2F6C8: E06D7363
    > 03E2F6F4: 6F4D3214 6F4A0000 + 33214 (MFC42.dll)
    > 03E2F6FC: 6F4D3211 6F4A0000 + 33211 (MFC42.dll)
    > 03E2F704: 6F4D3214 6F4A0000 + 33214 (MFC42.dll)
    > 03E2F708: 6F59E7F8 6F4A0000 + FE7F8 (MFC42.dll)
    > 03E2F710: 6F4C9E47 6F4A0000 + 29E47 (MFC42.dll)
    > 03E2F728: 0E51EFB6 0E470000 + AEFB6 (DivX.dll)
    03E2F72C: 002C8800 002B0000 + 18800
    03E2F730: 101B8B0C 100B0000 + 108B0C
    03E2F734: 03E2F740 03D30000 + FF740
    > 03E2F738: 0E503C35 0E470000 + 93C35 (DivX.dll)
    03E2F73C: 03E2F780 03D30000 + FF780
    03E2F740: 000023B5
    03E2F744: 0003D85B 00030000 + D85B
    03E2F748: 00000006
    > 03E2F78C: 0E4D3100 0E470000 + 63100 (DivX.dll)
    03E2F790: 101B8B84 100B0000 + 108B84
    03E2F794: 03E2F7F0 03D30000 + FF7F0
    03E2F798: 101B8590 100B0000 + 108590
    03E2F79C: 00000000
    > 03E2F7A0: 0E60FF40 0E470000 + 19FF40 (DivX.dll)
    03E2F7A4: 00000001
    > 03E2F7A8: 0E610B14 0E470000 + 1A0B14 (DivX.dll)
    03E2FFF0: 00000000
    03E2FFF4: 00519610 00400000 + 119610 (vegas70.exe)
    03E2FFF8: 00A7B160 00400000 + 67B160 (vegas70.exe)
    03E2FFFC: 00000000
    thought i would post this in case it could help. my guessing says it will to someone who is a MASTER of Vegas. i hope one of you is out there to see this and advise me on what to do next!
    cheers,
    vannny
  • Leslie Wand
    June 21, 2008 at 8:27 am
    afaik, vegas doesn’t render to divx.
    be more specific regarding what formats you have on the t/l and what you’re trying to render to.
    leslie
  • Mike Kujbida
    June 21, 2008 at 10:13 am
    I see that you’re using Vegas 7.0a
    The latest build is 7.0e so my first suggestion is to upgrade and see if that helps.
    DivX encoding works for me (I was lucky enough to get DivX Pro 6.8.3 when they were giving it away a while ago).
    If you find that version 7.0e gives you troubles, roll back to 7.0d.
    You can find that version in the Sony archives.
  • Vanny Vanhorn
    June 21, 2008 at 6:05 pm
    ok. well i am capturing footage from a game called Counter-Strike at a rate of 30 FPS. i then put those frames in a program called VideoMach to compress them into an AVI file using the DivX Codec. i have done this a million times before with now problems. i am beginning to believe it is vegas effin me over once again.
  • Vanny Vanhorn
    June 21, 2008 at 6:06 pm
    Thanks Mike. im currently installing rite now. LETS SAY A LIL PRAYER!
    cheers,
    vanny
  • Vanny Vanhorn
    June 21, 2008 at 6:20 pm
    IT WORKED!!!!!!!!!!!!!!!!!! THANK YOU A BILLION TIMES MIKE!!! WOOOOT!
    cheers,
    vannnny
  • Mike Kujbida
    June 22, 2008 at 2:19 am
    Vanny, I’m glad to hear that it worked!!
    Happy DivX editing 🙂
