Activity › Forums › Apple Final Cut Pro Legacy › so any REAL difference between 4.5 and 5?
Posted by Zman on May 19, 2005 at 5:12 amso what sthe verdict, is 5 worth all the hype? beside the multi cam is it all that and more or is it just ok I have 5 now?
Jason Mccaffrey replied 21 years, 4 months ago 5 Members · 4 Replies -
Walter Biscardi
May 19, 2005 at 7:18 amThe dynamic realtime feature sounds pretty neat. I’m looking forward to trying that out with my fibrechannel array.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Jerry Hofmann
May 19, 2005 at 12:19 pmWell for starters… it’s RT is more robust (i.e. there’s simply more RT on any machine), I love that you can size text in the Browser as well.
Capturing more than 2 audio tracks in a pass would make this a must have for many, and you can change the audio levels upon capture even from digital sources. The reconnection dialog box is better, and so is general response I think, especially in Tiger.
HDV support. Rendering quality is improved quite a bit as well. Scaling in particular has had a rewrite.
There’s a lot more than multicam involved here… There are improvements all over the app actually, probably over 100.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Mitch Ives
May 19, 2005 at 3:23 pm[ange] “so what sthe verdict, is 5 worth all the hype? beside the multi cam is it all that and more or is it just ok I have 5 now?”
The multicam alone is worth upgrading for. Personally, SoundTrack Pro’s ability to fix audio issues quickly, easily justified the upgrade. There’s a lot more, and many features not mentioned at NAB, but we were already sold…
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.com
http://www.insightproductions.com -
Jason Mccaffrey
May 19, 2005 at 3:50 pm
