Activity › Forums › Maxon Cinema 4D › S’n’T fine tOOning question
  • S’n’T fine tOOning question
    Posted by Caspar Stracke on May 27, 2011 at 4:12 am
    Hello to all S’n’T Rock’n’Roll specialists out there.
    I finally first time used this fantastic tool for a sequence.
    two quick questions:
    1.
    Is there a way (within all the 100+ parameters) how to make the lines smoother? The jump very much frame by frame, similar when rendering out a hardware preview in wireframe mode.. I realized anything below 2 pt is impossible. Already anti-aliased and put settings for animation. Slight difference but not much.
    2.
    If I want to have clean black lines on white with no shadow.or shadings..how can I get rid of all shadings. Added “Environment” on 100% still slight gray shades. And too much lighting has a bad effect on the sketch lines. So that won’t work either. Clue anyone?
    Corrado Carlevaro replied 15 years, 4 months ago 2 Members · 1 Reply
  • Corrado Carlevaro
    May 27, 2011 at 12:35 pm
    Second question: Render settings->Sketch&Toon->Shading tab, you’ll find settings for background and object shading, you can choose “custom color” white. You don’t need any light or Environment.
    First question: there is an Antialiasing setting just for S&T lines in Render Settings->Sketch&Toon->Render tab->Line AA. But if the problem are lines “jumping” from frame to frame I don’t think you can do much.
    C.C.
