Activity › Forums › Apple OS X › Snow Leopard No USB 2.0
Posted by Ricky Berg on December 5, 2011 at 7:36 pmHello,
I installed Snow Leopard on my iMac 2.4GHz Intel Core 2 Duo.
After the install my USB ports were downgraded to USB 1.1 being that my TV dongle did not work anymore as it needs a USB 2 port.I have been unable to resolve the issue.
Anybody got a clue?
Thanks in advance.
Ricky
Steve Modica replied 14 years, 1 month ago 3 Members · 6 Replies -
Steve Modica
December 5, 2011 at 8:41 pmThat sounds fishy to me. what if you put a USB 2.0 HUB in between? It should handle the translation. Does it work then?
SteveSteve Modica
CTO, Small Tree Communications -
Ricky Berg
December 13, 2011 at 2:15 pmHi Steve,
Thanks for replying.
Unfortunately it does not work with the USB 2.0 hub.
I found a strange solution on a website where they advise to put the USB dongle in the oven??? at a non destructive temperature.I will give it a go and let you know the endresult.
Best,
Ricky
Steve Modica
December 13, 2011 at 4:14 pmSo in this case, it almost sounds like a driver issue (I don’t think heating anything is a good idea).
If it was a USB 1.1/2.0 issue, the HUB would have resolved it. So it’s more likely, you are somehow missing a kext. If you put the thing on a working machine, see which kext loads (kextstat) and then see if you are missing it in /System/Library/Extensions. Maybe you have something that is old and is grabbing the thing. It could be a leftover from 10.5Steve
Steve Modica
Ricky Berg
January 16, 2012 at 12:04 pmIt finally worked when applying two options.
1. I removed the USB extension cable
2. I heated up the device for a while in the ovenMysteriously it works again 🙂
Steve Modica
April 12, 2012 at 8:05 pm[Dave Malone] “How long was “for a while”?”
Til golden brown and delicious
Steve Modica
