Activity Forums Apple OS X Snow Leopard – Jumbo Frames
  • Snow Leopard – Jumbo Frames
    Posted by David Hall on December 29, 2010 at 11:52 pm
    Hey everyone, I ran into an issue today while testing some Chelsio 10GB/s Ethernet adapters. I am attempting to setup Jumbo Frames, but am having some difficulty getting the settings to stick.
    I went into System Preferences > Networks, selected the 10GB Adapter, clicked Advanced, and went to the Ethernet tab. There I set Configure to Manual, MTU to Custom, and entered 9000 into the field. I click OK, then Apply, however when I go back into Advanced, the MTU field has defaulted back to 1500. Does anyone have any thoughts as to why this may be happening? Thanks.
    -Dave
    David Hall replied 15 years, 8 months ago 4 Members · 4 Replies
  • Vishal Shorghar
    December 30, 2010 at 6:08 am
    Hi Dave,
    You need to verify in ‘ifconfig’ command, The MTU size has been set but might not reflected in Mac GUI.
    After setting up MTU=9000 through GUI as you did above, open a command terminal and try this.
    #ifconfig cxgb
    example: for me it works as
    # ifconfig cxgb37 |grep -i MTU
    cxgb37: flags=8863 mtu 9000
    ->Apert from these you can verify through tcpdump , if you run some traffic on Jumbo frame enabled interface, you will see bigger packets in sniffer e.g tcpdump/wireshark.
    Let me know if it helps …
    vishal
    Mac OS x 10Gb networking engineer.
  • Rob Brambila
    December 30, 2010 at 6:35 pm
    David,
    Try setting your Jumbo frames in Terminal. Make sure you sudo in as the root user. This should set it correctly. Then check with ifconfig to see if it stuck.
    Rob Brambila
    Director of Technology
    ProMAX Systems
    949-861-2700
    rob.brambila@promax.com
    http://www.promax.com
  • Steve Modica
    December 30, 2010 at 7:53 pm
    This is a bug in the GUI. They are probably set. You can see with ifconfig. It’s an old bug. It just doesn’t show the change.
    Steve Modica
    CTO, Small Tree Communications
  • David Hall
    January 3, 2011 at 6:44 pm
    Thanks for the help everyone. I will try all of these.
    David Hall
    Support Technician
    New Media Hollywood
    Apple Certified Technical Coordinator 10.6
