Activity Forums Maxon Cinema 4D Snow covering
  • Snow covering
    Posted by Brian Stenson on October 26, 2007 at 10:29 am
    Hey,
    I am starting put together a christmas scene. I have modelled houses trees etc but am having trouble getting a realistic snow covering on them. Does anyone have any suggestions for making a winter wonderland?
    Brian Jones replied 18 years, 11 months ago 2 Members · 1 Reply
  • Brian Jones
    October 28, 2007 at 6:07 am
    thick snow probably is best to model in. If you just want color and/or slight bumpiness it can be done with a material. Try using the falloff shader to give ‘snow’ only on the tops of things.
    There is a snowy mountain tutorial by Cactus Dan here https://library.creativecow.net/articles/libisch_dan/moonlight_mountain.php
    it uses 7.3 so the bhodinut shaders it uses have long been absorbed and lost the bhodinut part of the name but it’s still there (Material editor/File/Shader/Nukei). He uses the Falloff shader here so even if it’s not what you are after it should give you a way to think about. (same thing could be done with a Layer in the shader instead of Nukei)
