Activity Forums Apple Final Cut Pro Legacy Snapping Tool
  • Walter Biscardi
    December 27, 2007 at 2:50 am
    [Lot Mallari] “Is this a FCP bug?”
    Yes, this has been documented in several threads on this forum. No idea when Apple will fix it.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Ron James
    February 1, 2008 at 9:36 pm
    I don’t think it’s enabling itself. You’re probably hitting n when you drag and the setting resets after the action is executed. Whereas before the setting would stick (the way it should be).
  • Walter Biscardi
    February 1, 2008 at 10:21 pm
    [Ronnie James] “I don’t think it’s enabling itself. You’re probably hitting n when you drag and the setting resets after the action is executed. Whereas before the setting would stick (the way it should be).”
    It is enabling itself. It’s a bug in 6.0.2 and Apple has provided the workaround.
    https://blogs.creativecow.net/node/377
    Read my Blog!
  • Darren Andrews
    March 20, 2008 at 10:32 am
    Sounds like I’m having the opposite problem as everyone else on this thread. I turn snapping on, drag a clip in the timeline, the snapping works but immediately turns off once I release the mouse button, without hitting the N key or clicking the snapping button in the timeline. Dragging the next clip, hitting the N key turns snapping back on, until I drop that clip and it turns off again.
    This isn’t the end of the world, but it’s very frustrating to say the least. Something that’s worked perfectly in every previous Final Cut Pro version suddenly stops working when I upgrade.
    Does anyone have any ideas? Thanks.
Page 2 of 2
