Activity › Forums › Apple Final Cut Pro Legacy › snapping noise
snapping noise
Posted by Joseph Sir on July 18, 2009 at 11:37 pmI am new to using FCP but i have found that a lot of my videos have a random snapping or cracking noise in the audio. almost a pop……not sure what im doing wrong but its heard when exported to DVD and watched as well. is it my camera? cant figure it out……..any help would be much appreciated
Joseph Sir replied 17 years, 2 months ago 5 Members · 6 Replies -
Zane Barker
July 19, 2009 at 12:40 amCould you please provide info an the files you are using that are having the issue.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Andy Mees
July 19, 2009 at 12:46 amFCP tends to prefer 48kHz aiff audio … its possible that the distortion you’re hearing may be due to an incompatibility with a less supported audio codec. This is especially common if and when you try working with MP3 audio in an FCP timeline.
Could that be the issue?
Joseph Sir
July 19, 2009 at 3:25 amim importing to my external hard drive direcly from the raw footage captured on a JVC mini dv camcorder. I put it in FCP, do my basic editing, render it all, export it and put it on a dvd as a quicktime, and it makes random poping noises…
John Fishback
July 19, 2009 at 6:53 pmAre the pops truly random or do they occur in the same place every time? Have you checked your audio levels inside FCP. Are there any clips(meter goes red). Also, as Andy says, check your clip properties and see what sample rate is listed. Some camcorders record audio with a sample rate other than 48k (eg. 44.1 or 32kHz). Also, try an audio mixdown: Sequence Menu > Render Only > Mixdown and see if that helps.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Ray Chung
July 20, 2009 at 6:02 amSometimes, straight cuts in audio tracks can cause slight ‘pops’ on playback and even output, even when the sound is 48k AIFFs. It can happen more often, as I’ve encountered, with audio that was originally MP3s or WAVs and transcoded into AIFF’s, or even 44.1kHz stuff that’s upsampled to 48. And it can also happen more often when you have a lot of soundtracks layered together….like 8 tracks (or 4 stereo tracks), for example. Sometimes I add little crossfades at the cut points and/or extend the handles. Sound processing in FCP is still rather quirky at times (artifacts left behind where there should be silence, or the content shifting within the track after rendering audio effects). Also try raising the audio playback quality under User Preferences and see if that helps during playback.
