Activity › Forums › Apple Final Cut Pro Legacy › Snapping Argghhhh
  • Snapping Argghhhh
    Posted by Hal Sloane on May 21, 2010 at 2:18 pm
    Greetings,
    Hope I’m not being redundant here but searches didn’t turn up an answer for this one. I am running FCP 7 and after having updated from 5 it seems that the snapping function has been changed. I used to be able to toggle snapping on and off and it would stay in the desired mode until I toggled the other way. Now with FCP 7 it seems that if toggled off it returns to the default on position after making any kind of edit. I would love to be able to turn it off and leave it off until I need it. Am I missing something simple here???
    Hal Sloane replied 16 years, 4 months ago 4 Members · 4 Replies
  • Michael Craven
    May 21, 2010 at 3:07 pm
    Hmmmm…. works for me on 7. Have you tried trashing prefs? Did you say you did an upgrade or clean install? If upgrade, that could be your problem.
  • Rob Grauert
    May 21, 2010 at 3:34 pm
    I work on FCP6, and I noticed if you toggle snapping WHILE dragging a clip, it will toggle back to its original status once you drop the clip.
    So to keep snapping on or off, make sure you are not in the middle of dragging a clip when you toggle it.
    This has been consistent for me at home and at work, so I don’t think I’m experience a big myself.
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Michael Sacci
    May 21, 2010 at 4:27 pm
    if you do not have a clip selected and active “n” will toggle it on and off and it stays. IF you are moving a clip and hit “n” it will change back once you let the clip go.
    Once you get use to it it is a nice way to do it. I like it better but it did take some getting use to.
  • Hal Sloane
    June 1, 2010 at 2:19 pm
    That must be it. I often reach up for the n key in the midst of an edit. Makes sense.
    Thanks for the response.
    Hal
