Activity › Forums › Adobe After Effects › Snap to guides not working in AE CS6
Posted by Paul Roper on November 15, 2012 at 12:07 pmI cannot get path points to snap to guides. Layers will snap, but path points (nor bézier handles) will not. Is this normal? It’s just something I’ve lived with, but it’s getting to really annoy me. Is this the same on everyone else’s AE?
Could it be some graphics card anomaly? I’m running a MacPro with 2x Nvidia Quadro 4000s.
– Paul
Guto Cardoso replied 12 years, 4 months ago 6 Members · 17 Replies -
John Cuevas
November 15, 2012 at 12:47 pmI just got mask and motion path points to snap the guides I created. Exactly what and how are you trying to accomplish this, also a screen shot of your comp window might be helpful.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Roland R. kahlenberg
November 15, 2012 at 2:04 pmHave you enabled Snap to Guides? You do this via the View Menu or the CTRL+Shift+; keys.
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7) -
John Cuevas
November 15, 2012 at 2:36 pmNow I feel stupid, I had no idea you could actually turn that off. Good to know, thanks Roland.
Paul Roper
November 15, 2012 at 3:32 pmRight – I’ve discovered it only under fairly specific circumstances – looks like a bug to me; I’d be interested to have other people try it out:
1. Create a new comp.
2. Using any of the shape tools (polystar is a good one – plenty of points to move around) hold down option/alt BEFORE and while dragging to create an editable path shape, not a parametric one.
3. Drag a guide onto the comp and ensure ‘snap to guides’ is on.
4. Drag one of the points around, all over the guides, with no snapping. You might have to open up the shape layer and click on the word ‘Path 1’ to get to the points without moving the whole thing.
5. Just to make sure that some snapping is on, drag the whole layer, and see it snap to the guide.
If anyone else can recreate this, I’ll send a bug report to Adobe. In fact we should all let them know about this.
– Paul
Ridley Walker
November 15, 2012 at 4:26 pm[Paul Roper] “If anyone else can recreate this, I’ll send a bug report to Adobe. In fact we should all let them know about this.
“Same result here with a polystar shape.
Todd Kopriva
November 16, 2012 at 12:08 amI think that vertices of shape layer paths don’t snap. It’s not exactly a bug; it’s just a limitation in the feature. I’ll go down the hall and check with the engineer responsible for this part of the code and check—and lodge an enhancement request if I’m right.
After Effects team blog
November 16, 2012 at 12:33 am[Todd Kopriva] “I think that vertices of shape layer paths don’t snap”
But mask vertices do snap to guides. Further, for a Shape Layer, its boundaries do not snap when they are initially created and still selected. The user has to deselect and then reselect the Shape Layer before its layer boundaries snap to the guides.
HTH
Todd Kopriva
November 16, 2012 at 12:35 am> But mask vertices do snap to guides.
Yep. These are actually implemented in different parts of the code, so it’s not a given that something that works for one works for the other. But the request has been made.
November 16, 2012 at 12:51 am[Todd Kopriva] “These are actually implemented in different parts of the code, so it’s not a given that something that works for one works for the other.”
Agreed Todd. However, I believe that the similarity between paths for Shape Layers and Masks; that they are used to define an area, would make most users believe that it’s a bug rather than an intended feature. 😀
Cheers
