Activity Forums Maxon Cinema 4D Snap Question
  • Snap Question
    Posted by Martín Gonzalez on February 17, 2021 at 5:24 pm
    Hi, so far i know that if snapping is activated and the move tool is selected, when i click on an empty space, I can have the selected object stuck to the cursor by its axis, ready to be dropped to a snap, like a vertex or an edge. that way, if I align its axis to a vertex, i can align an object to another, say vertex to vertex, for example.
    what i’d like to do is something similar, but i can’t find a way to achieve it. i want to rotate an object, but instead of using the rotation orb, i’d like to grab it by a vertex so i can snap it somewhere else while using the axis i had set before
    TL;DR: I want to rotate the green object so the vertex marked with red snaps to the vertex marked with green on the red object:
    do i even make sense? i tried rotating it as is using the orb but it won’t snap.
    Martín Gonzalez replied 5 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
