Activity Forums Adobe After Effects Snap Keyframes To Nearest Frame
  • Snap Keyframes To Nearest Frame
    Posted by Shane Newville on November 29, 2011 at 4:31 am
    I just finished animating something and realized I had my comps set to 29.97 fps instead of 25 fps. I changed the comp settings to 25, but all of my animation keyframes stayed in place. Is there a way to select them all and make them snap to the nearest keyframe? This would be a pain to correct one.
    Blender has a an easy fix that lets you snap all keyframes to the nearest frame. So I’m hoping something as bi as After Effects can do it too.
    ShaneNewville.com
    Steve Blacker replied 14 years, 9 months ago 2 Members · 1 Reply
  • Steve Blacker
    November 29, 2011 at 9:33 pm
    Not that I know of – I’ve had to go through and manually nudge keyframes in the past like this.
    It’s only work if you’d rather be doing something else…
