Activity Forums Adobe After Effects snap 3D layer to camera position??
  • snap 3D layer to camera position??
    Posted by Accountclosedduetonorealnameused on January 11, 2008 at 7:22 pm
    I am doing a camera “fly though” in a comp.
    Problem is, I want to add layers along the way and have them orient in front of the camera. Because when i add a lyers it takes some time to center it in front of the Camera.
    Is there a way (maybe a script) that would just repo the 3D layer right smack in front of the camera?
  • Steve Roberts
    January 11, 2008 at 7:35 pm
    You know …
    … you might be able to use Particular (if you have it) and set it to emit particles along the camera path. The particle (custom) would be a comp consisting of the still images, one pfer frame. So Particular would emit these frames along the path of the camera.
    Then you’d set the physics time (sorry, not at the AE workstation) to zero at some point so the stills are frozen in position.
    Of course, this assumes the stills are to be spaced evenly apart. Anyway, it’s just a thought. 🙂
  • Dick Smith
    January 11, 2008 at 7:53 pm
    these are an essential in my arsenal
    LAYER TOOLS
    also, copy and paste posistion/rotation werks fine, then just slide the ‘z’ into view
    there might be a script on aenhancers.com
  • Accountclosedduetonorealnameused
    January 11, 2008 at 8:21 pm
    excellent, exactly what I was looking for, thx
