Activity Forums VEGAS Pro Smoothly changing the pitch continuously in one audio track?
  • Smoothly changing the pitch continuously in one audio track?
    Posted by Seth Kopchu on December 12, 2018 at 12:49 am
    I’m using Vegas Pro 14, and I’ll be doing a video where a character’s dialogue will gradually become lower and lower in pitch. Instead of manually cutting the audio into sections, is there a way to set the pitch to gradually lower slowly but all at once, a la when you hit the audio hot key and can raise or lower an audio track’s volume and depending on what you set it at, the edited sound will either raise smoothly, like in this video:
    https://www.youtube.com/watch?v=CkDU7b1jtxY
    Greg Wedgwood replied 2 years, 10 months ago 3 Members · 2 Replies
  • John Rofrano
    December 18, 2018 at 12:29 pm
    [Seth Kopchu] “Instead of manually cutting the audio into sections, is there a way to set the pitch to gradually lower slowly but all at once”
    No. The pitch shifting in Vegas Pro is only available on an entire event so gradually changing it is not possible.
    You would need to find an audio plug-in that can alter the pitch which also supports automation so that you could do it over time.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Greg Wedgwood
    October 4, 2023 at 11:01 am
    Would you know where to find those plugins or what they’re called?
    Would be amazing if you knew 🙂
