Activity Forums Adobe After Effects Smoothing over internet video clips
  • Smoothing over internet video clips
    Posted by Seanwinn on February 11, 2006 at 2:21 pm
    I have some short clips from the internet that I’m using in a 5 minute video – converted to AVI’s from WMV’s.
    In the resolution of 720×480 I’m editing in, you get that ‘jumping pixelation’ look from low res video that’s been blown up slighty.
    Is there any way in After effects to smooth that out some?
    Sean Winn
    Seanwinn replied 20 years, 7 months ago 2 Members · 2 Replies
  • Mike Clasby
    February 12, 2006 at 10:42 pm
    Maybe try the new effect in AE7 “Smart Blur” (30 day demo at Adobe).
    Or Remove Grain in AE6.5.
    Or I think the best solution and fastest is to Re-encode the WMV’s to a larger size with Windows Media Encoder 9 which will smooth itself.
    Of course you can’t get any better quality than you had in the smaller wmv’s, but if the smaller ones weren’t pixilated, then the new 720×480 shouldn’t be either.
    https://www.microsoft.com/windows/windowsmedia/9series/encoder/default.aspx
    It’s free.
    Here’ a step by step if you haven’t use the WMV Encoder before:
    Convert A File
    Source File; Your smaller wmv
    Output File: choose a name
    File Download – Computer Playback
    Video, Audio: the second choice in the dropdown, DVD quality (2 Mbps VBR) should be fine (it’s 640×480, but we’ll change to 720×40 in the properties panel below)
    Next – nothing to change
    Next – uncheck the box at the bottom – Begin converting when I click Finish (so we can change the 640 to 720)
    Finish
    Now click the Properties Tab on the tool bar.
    Video Size Tab – Change the Width from 640 to 720.
    Hit the Apply button.
    Click the start encoding button on the toolbar.
    I re-encoded a 480×360 to 720×480 and the wmv9 codec smoothes the pixelation you get from going from wmv to AVI.
    I have AE 6.5 and it can use the wmv9’s fine.
  • Seanwinn
    February 13, 2006 at 2:13 am
    Thanks so much yikesmikes…
