Activity › Forums › Adobe Premiere Pro › smoothing out cuts between clips
  • smoothing out cuts between clips
    Posted by Raymond Tarry on November 2, 2009 at 6:35 pm
    Hello, I’m using Adobe Premiere Pro 1.5 to edit my short film and I’ve got some clips that have noticible “blips”, or seem rough when when put together. The reasons appear to be:
    1. Clip A has a light background and Clip B baackground is dark
    2. Clip A is a panning shot and clip B is locked down
    3. The is a blank frame on the end of Clip A (easily corrected)
    Is there anyway to smooth out these cuts?
    Thanks – Raymond
    Mark Hollis replied 16 years, 11 months ago 2 Members · 3 Replies
  • Mark Hollis
    November 2, 2009 at 6:41 pm
    Dissolves tend to work just fine, though I find that some producers like cuts — the more jarring, the better.
    If you want the look of a cut, make your dissolve transition very short. I generally throw in dissolves very quickly by navigating to an edit ([PgUp] and [PgDn] work very quickly) and then using [Ctrl]-D to put in my default transition, which you can make a cross-dissolve. Use your Preferences to change the rate of the default transition if you are going to do a whole lot of them and change the rate to something like 5 frames or so. They’ll be differentiated from a regular 1 second dissolve and tend to look like cuts.
    What if there were no hypothetical questions?
  • Raymond Tarry
    November 4, 2009 at 7:02 pm
    Thanks Mark, I tried dissolves before with mixed results. Even with one frame on either side of the clip, I didn’t notice much difference. Maybe I don’t understand about the Preferences thing.
    Thanks Raymond
  • Mark Hollis
    November 5, 2009 at 5:32 pm
    The longer the dissolve, the smoother the transition. Generally, when I have stills moving into moving video, I’ll do a 1 second dissolve that gives me a half second crossfade to each side — unless I need to start the transition early or late because there is not enough material on either end.
    Short dissolves get you in and out of jams but lots of material that is moving benefits from longer dissolve transitions.
    One thing I tell people who are shooting material is that most of the movement happens in the edit. You make a film or program move by cutting from one shot to another so that the viewer does not get bored with just one stable shot (emphasis on the word stable here because stable shots give you the best means by which you can tell a story).
    But if you are doing another Blair Witch Project, you want moving shots with cuts between them. That exaggerates the nature of the movement (usually termed “visual whiplash”).
    In your case, you are looking for something more sedate. Assuming your video is color-corrected and that everything is just fine, any abrupt transition will benefit from a dissolve, a dip to black, a dip to color or a similar crossfade transition.
