Activity Forums Adobe After Effects smoothing out a pan
  • smoothing out a pan
    Posted by Chris Bending on June 27, 2009 at 8:10 pm
    Hey guys,
    I have some footage of a short pan I shot the otherday…
    https://www.youtube.com/watch?v=sJnjl3Wg1XA
    My problem is that the pan is not a very smooth motion, what would be the best way of smoothing the shot out?
    Chris
    Luke Roman replied 17 years, 1 month ago 4 Members · 5 Replies
  • Immanuel Morales
    June 28, 2009 at 2:49 am
    hm, perhaps just some simple time remapping?
    if somebody does have an easier solution i’ll be suprised.
    Dead the Fed
  • Stuart Elith
    June 29, 2009 at 4:15 am
    Something that may help (if you choose to go with time-remapping) is to take a still of the scene and just keyframe its position over the top, using the same start and end positions. This will provide you with a perfectly smooth pan which you can then reference for realigning points of the footage to match up with it.
    (alternatively, I might even try cheating with a still as the final!). You could even add a bit of lens distortion around the edge of the frame to add a bit of imperfection, and a X-axis wiggle of a few pixels so that the pan isn’t PERFECTLY smooth. Probably wouldn’t be acceptable in most situations though 🙂
  • Immanuel Morales
    June 29, 2009 at 2:52 pm
    Stuart of course! Why didn’t i think of it!
    Chris i’m with Stuart on this one
    Dead the Fed
  • Chris Bending
    June 29, 2009 at 3:01 pm
    Thanks for the replies guys, I ended up tracking/stabilising and keyframing the position.
    Cheers, Chris
  • Luke Roman
    July 31, 2009 at 6:13 pm
    Mark Christiansen(from the orphanage) Covers this in his AE studio technique books (6.5 -7. and now updated to cs4 page 252 in cs4 print of book”stabalizing a moving shot”)
    Basically you track the motion of the shot (a stabalize track ) – creat null w 3D enabled- – select all ANCHOR POINT keyframes fromstabalized shot – copy those keys to null – apply smooth expression(premade in expressions menu) to null..you can change values but default can be decent .. – AND PARENT your camera to the NULL– and LASTLY BUY HIS BOOK it really really helps anyone from beginer to expert in differetn ways..
    https://www.amazon.com/gp/product/0321592018?ie=UTF8&tag=afteeffescri-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=0321592018
    I Love this guy books. I bought the 6.5 techniques bak in the day and it really accelerated my ae knowledge. .and now i got he CS4 updated book with new chapetersand addtional info and new examples..
    ALSO he metnions to try MOCHA TRAKER for after effects.. wich i ddint know is a stand alone and COMES with AE CS4!!!! its in the cs4 directory and it even has a shortcut to the mocha app in programfiles.. HAD AE cs4 since beta and just read this in his book!!
