Activity Forums Adobe After Effects Smoothing out 1Hz luminance modulations (fixing a poor DIY telecine)
  • Smoothing out 1Hz luminance modulations (fixing a poor DIY telecine)
    Posted by Jack Kelly on November 8, 2005 at 2:23 pm
    Hi there,
    A client of mine has just done a DIY transfer from standard-8mm to DV by pointing his DV camera at his 8mm projector’s screen! The image quality is surprisingly good EXCEPT that the luminance is modulated at a frequency of about 1Hz. I assume this is because the DV camera was running at 25fps whilst the film camera was going at 24fps so there’s a 1-second beat frequency. This luminance modulation is subtle enough to mean that the client (an ex-Physics researcher) didn’t notice the problem… but, still… it needs to be fixed.
    Is there any way to smooth out these liminance oscillations? In other words, can I normalise luminance?
    I have considered animating some levels keyframes but this sounds like a very painful procedure (there’s 40 minutes of footage).
    Any ideas would be very helpful!
    Many thanks,
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
    Jack Kelly replied 20 years, 10 months ago 2 Members · 2 Replies
  • Chris Smith
    November 8, 2005 at 2:33 pm
    Hey Jack, you may want to give the Color Stabilizer effect a try. It’s pretty self-explanatory:
    Effect>Adjust>Color Stabilizer
    Chris Smith
    https://www.sugarfilmproduction.com
  • Jack Kelly
    November 8, 2005 at 6:27 pm
    Thanks a lot for your replies. I’ll try the Color Stabilizer effect a go.
    Dave: do you have a link to the thread from 2 weeks ago? It wouldn’t have been my client… he did the transfer a few days ago.
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
