Activity Forums Adobe After Effects Expressions Smoothing a position, after expression.
  • Smoothing a position, after expression.
    Posted by Cassius Marques on February 23, 2018 at 8:52 pm
    Hey guys.
    The summary:
    I have a 3d spline. In c4d I used an align to spline so I’d get the 3d position of a layer running along this spline. I baked this to actual position and exported to AE.
    Now in AE I’m using this exported null to guide a camera to do a flythrough in said spline.
    I baked the 3d position linearly for the duration. So in AE i’m using the .valueAtTime method with a time remmap property as argument. This way I can do easy ins and outs, essentially controlling the flow of the movement (temporally changing the velocity from linear to whatever I want).
    The Problem:
    Spacially it still follows the exact spline path, so during sharp turns it creates an undisired movement. I can’t use “smooth” since it evaluates keyframe values and not expressions (right?). So, any ideas how I can smooth this? Preferably with a control in amount and when?
    Cassius Marques
    http://www.zapfilmes.com
    Cassius Marques replied 8 years, 6 months ago 2 Members · 3 Replies
  • Cassius Marques
    February 23, 2018 at 9:01 pm
    nevermind, I’m stupid. I can smooth the guide layer prior to passing the value to the actual camera guide layer.
    Cassius Marques
  • Dan Ebberts
    February 23, 2018 at 9:02 pm
    I guess you could try converting the expression to keyframes and then smoothing the result.
    Dan
  • Cassius Marques
    February 23, 2018 at 9:17 pm
    Yeah, I know that. But since I’m doing the bulk of the animation now I need to be able to do the smoothing on the fly along with the velocity changes. So keep going back and baking everytime I change the speed is a no go.
    But as I said before, I should have thought better before posting. It was easy.
    I rushed to post because I knew if I didn’t figure it out, you’d probably write something better than I ever could, hahaha.
    Thanks for taking the time to read anyway!
    Cassius Marques
