Activity Forums Maxon Cinema 4D smoothing a bend
  • smoothing a bend
    Posted by Rachel Max on June 5, 2006 at 7:47 pm
    Hello – I am trying to smooth a bend in a pipe. I’ve maxed out the height segments for the cylinder. Is there any way to apply a certain number of segments to a specific part of a cylinder? I don’t need 1000 segments distributed over the entire pipe since there is only one bend.
    I’ve uploaded an image here:
    https://www.rachelmax.com/cd4_issue.html
    Thanks in advance,
    Rachel
    Rachel Max replied 20 years, 3 months ago 3 Members · 3 Replies
  • Brian Jones
    June 5, 2006 at 8:44 pm
    With the cylinder as a primitive then no, but if you make the cylinder editable the you can make divisions with the knife tool in the ‘right place’
  • Mylenium
    June 6, 2006 at 5:13 am
    [rachelm]
    Thanks in advance,
    Rachel”
    You should greate your pipe using a Sweep Nurbs. Not only will it be more smooth (because it’s based on splines, it will create more geometry in the curved area), but also much easier to edit. also from a technical standpoint it’s better technique.(no offence)
    Mylenium
    [Pour Myl
  • Rachel Max
    June 7, 2006 at 10:54 pm
    thanks – I will do that. I am fumbling my way through Cinema as a newbie.
    – Rachel
