Activity › Forums › Adobe After Effects › Smoother morph effect?
  • Smoother morph effect?
    Posted by Alayne Williams on February 21, 2015 at 9:27 pm
    Hello! I’m in need of assistance,
    A project I’ve been working on requires a character of mine(that I made in PS and transferred to AE)to have their hair move like fire. But, considering I only made three drawings/frames for her hair animation, I figured it would look bad flickering quickly. I wanted it to be a smooth transition and to look cool, but to still move as if it were fire, so I learned how to use the Morph Effect thanks to Eran Stern:
    https://www.youtube.com/watch?v=iMfMvdJyeSA
    This was close to what I wanted, but it still came out a bit strange, I suppose it’s because that the frames I want it to morph into aren’t as similar to one another and it’s causing the effect to maybe fade out into some water like thing? But here is a link to my sample of what I got:
    https://vimeo.com/120200416
    While two of her hair frames(the beginning then the end when it returns to the starting position) seem to morph perfectly into one another, the frame at the 2 second mark produces a water-like wave effect as if it’s forcing itself to morph to the next, and then it does it again for the next frame, and I’m wondering if there’s a way to fix that without having to make more drawings for her hair. Please help, it would be greatly appreciated!
    ~Alayne Williams
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Daniel Waldron replied 11 years, 7 months ago 2 Members · 1 Reply
  • Daniel Waldron
    February 24, 2015 at 10:42 pm
    You might be better off using just one layer for her hair and using the Puppet Tool to animate it.
