Activity › Forums › Adobe After Effects › Smoothening the Motion-field & Optical-flow of Video
  • Smoothening the Motion-field & Optical-flow of Video
    Posted by Hayden Martin on July 10, 2015 at 6:52 am
    Hello
    I’ve shot footage of models against green-screen on a 2.5K camera at 25p knowing that I cannot shoot any faster to achieve slow motion – to give me a higher degree of flexibility when it comes to remapping their movement I coordinated the models to move as slowly as possible.
    Playing back the motion at 100% looks relatively smooth, although giveaways are apparent in the motion – whilst slowly changing poses from A to B, the models struggled to do so with absolute fluidity as observed in real slow motion where the movement would typically be fast whilst shot on a higher frame-rate…
    My question is this:
    If I want to eliminate minor bumps in the fluidity of the motion from pose A to B, could I simply run an analyses of the footage’s Motion-field / Optical-flow then create a smoothen effect that essentially averages out this data in iterations of 100 frames…?
    It seems feasible, and theoretically easier if shot against green-screen as there would be no interfering FG / BG information…
    I’ve asked a similar question before but was redirected to interpolation hardware – I am sure my aims could be achieved through good use of expressions though…
    Many thanks,
    Hayden
    Chris Wright replied 11 years, 2 months ago 3 Members · 2 Replies
  • Walter Soyka
    July 10, 2015 at 3:59 pm
    If you want to try processing the motion vectors, you’ll need a tool that gives you access to them. Twixtor Pro allows you to import/export motion vectors. Maybe you could try the demo to see if you can get the effect you’re looking for?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Chris Wright
    July 10, 2015 at 5:03 pm
    AE’s timewarp can set vectors numbers higher, it supports roto masks if you precomp, so the bg won’t get interpolated.
    Also, you can precomp a video, precompose it, right click timestretch 50%, then apply timewarp 50% to the precomp.
    That will create,decimate and average movement out..as long as both numbers match. The higher the number, the more interpolation at a cost of softness.
    filter-extreme will reduce softening of the image, but at a huge cpu cost.
    If you need perfect quality, terrenex came out with a mini-hardware box. Or as walter said, twixtor pro has spline support to manually guide the warping.
