Activity › Forums › Adobe After Effects › Smoothen Motion Tracking Result???
Posted by Sascha Engel on March 9, 2010 at 2:42 pmHi Everybody,
got a little problem: I tracked the Motion of a shot, to attach some text to it – so it scales and moves with it. But the tracking is too precies – which results in too much motion (jiggering and jerking of the text) – any way to smoothen the tracking result a bit – so the attached text moves less???
Thanx a lot for any help!!!!
Sascha
James Autery replied 9 years, 6 months ago 4 Members · 7 Replies -
Joey Foreman
March 9, 2010 at 3:09 pmTry selecting all the keyframes and adding Smoother (Window > Smoother), playing with different values. Undo if you don’t like the results, and tweak to taste.
There is also a Smooth expression, but I haven’t used it. -
Philippe Lessard
March 9, 2010 at 3:10 pmHi Sasha,
If you look in your windows menu in After Effects, you should see the smoother, click it, it open a windows where you can choose a tolerance to smooth your “pos/rot/scale” keys.Select all the key you want to smooth then try to use a tolerance of 1 ,should do the trick, otherwise play with the tolerance.There also a script called tracker viz, but I never tried it, maybe you should look at it.
Hope this help
Sascha Engel
March 9, 2010 at 7:25 pmHI Thanx for the fast Reaction. I tried it, but I am facing some problems. I can just select always some keyframes in a row – then the smoother ‘apply’ button highlightens. When I select all in one line – it stays greyed out. And I do not have options to choose (just spatial). When it’s set to 1 it seems to make it even jerkier than it was 🙁
Any idea?
Sascha
Sascha Engel
March 10, 2010 at 7:12 amThanx Dave, I will give it a shot.
Funny is that it’s not bad – it just tracks it too good 🙂
I will try the pre-blur, maybe that will bake the cake.Greetings,
Sascha
Sascha Engel
March 11, 2010 at 6:49 amWell, I tried a lot, re-tracking, smoothening, just applying to x-axis and so on.
But it is still jerky.
Could it have to do something with the fact, that it is Apple Intermediate Codec / Quicktime file?Sascha
Joey Foreman
March 11, 2010 at 6:55 amDoubtful. AIC is a great codec.
Have you tried just randomly removing intermittent keyframes, changing their interpolation, and/or selecting all but the 1st and last keyframes, right-clicking and choosing Rove Across Time?
Also try posting this to the Expressions forum to see if anyone there has some ideas.
James Autery
March 19, 2017 at 12:57 am
