Activity › Forums › Apple Final Cut Pro Legacy › SmoothCam problem
  • SmoothCam problem
    Posted by Egor Appolonov on June 19, 2009 at 9:55 pm
    Hi everyone!
    Please help me with a SmoothCam. It doesn’t work. I’ve just installed ProApps Update 2008 but without any result… Could you tell me how to fix it? I’m trying to use the Effect by dragging it to a video clip but nothing happens..
    Andy Casciato replied 17 years, 3 months ago 3 Members · 4 Replies
  • Ernie Santella
    June 19, 2009 at 10:49 pm
    Not sure why it doesn’t work, but when you get it working, the best tip I’ve gotten is to make the clip you want to fix stand-alone. If you don’t, SmoothCam goes back the original file (which could be really long) and analyzes the entire file, not just your edited portion. So, export the clip and re-import it. It will be mucho faster!
  • Egor Appolonov
    June 19, 2009 at 10:51 pm
    And in wich program you’re suggesting to do this? Motion?
  • Ernie Santella
    June 20, 2009 at 1:23 am
    Final Cut Pro.
  • Andy Casciato
    July 4, 2009 at 8:34 am
    Actually, just had this same exacty problem, UNTIL, I output the file i wanted to analyze as a quicktime file, not AVI. I believe it was the formate which was the issue. This might seriously help. 🙂 Woohoo! Honestly psyched over hear now I figured it outl. . . Phew!. . . saving the shot I hope 😉
    COW ON !
