Activity Forums Apple Final Cut Pro Legacy Smoothcam cropping image
  • Smoothcam cropping image
    Posted by Sam Roberts on June 12, 2009 at 1:41 am
    I smoothcamed a shot and then wanted to add a freeze frame of the last frame so the clip would freeze at the end. I noticed the freeze frame and the smoothcam footage were different causing a noticeable jump. Seems that when you apply smoothcam it crops the picture a bit. Is this normal?
    Sam Roberts replied 17 years, 2 months ago 3 Members · 3 Replies
  • David Roth weiss
    June 12, 2009 at 1:47 am
    It has to crop as it adjusts for shakiness, otherwise the edges of your frame would be black when the edge would move out of the frame. Use the freeze frame from the last frame of the smoothcam shot.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Arnie Schlissel
    June 12, 2009 at 4:04 am
    All image stabilizers do this. if the stabilizer sees your footage move left, it moves it back to the right. If it sees your footage move up, it moves it back down. So when you move the shot to the right or down, it exposes black on the left or top.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Sam Roberts
    June 12, 2009 at 2:12 pm
    Interesting, thanks guys for explaining.
