Activity › Forums › Apple Final Cut Pro Legacy › smoothcam – anamorphic
  • smoothcam – anamorphic
    Posted by Peter Ralph on August 25, 2009 at 12:36 am
    I want to apply smoothcam to some downconverted HDV 16:9 footage inside an SD project.
    I export the clip I want to smooth as a self-contained QT and then reimport, it comes back in as 16:9 with black bars top and bottom – but when I apply smoothcam it scales up to 4:3
    I have played with the project settings but no luck
    any ideas?
    Peter Ralph
    https://www.shootingbynumbers.com
    Peter Ralph replied 17 years, 1 month ago 2 Members · 2 Replies
  • Michael Sacci
    August 25, 2009 at 1:07 am
    And what would those settings be?
    When you export the clip to make it a SC movie, are you downconverting it, are you making it anamorphic, or are you keeping it a HDV file? The sequence that you are bring it in to is that SD 4:3?
  • Peter Ralph
    August 25, 2009 at 12:40 pm
    I guess the captured clip was messed up in some way – I exported from QT and the problem is fixed
    Peter Ralph
