Activity › Forums › Adobe After Effects › smooth up the movement of a footage
  • smooth up the movement of a footage
    Posted by Jason Creetee on January 26, 2012 at 4:37 pm
    I shot a 10 secs footage of a landscape with a panning movement. I am trying to showcase blocks of buildings as a panoramic city view. However, the movement was not smooth and consistent enough while shooting and you can feel slowing down and speeding up when I review the footage. Is that a way to motion tracking the footage and make the movement look smooth?
    What I did is just putting a tripod and panning a camera around toward a city.I really appreciate the help.
    Michael Szalapski replied 14 years, 8 months ago 3 Members · 5 Replies
  • Michael Szalapski
    January 26, 2012 at 7:21 pm
    However, if reshooting is out of the question, just stabilize your shot (if you’re using CS5.5, these instructions are for using the legacy stabilizer).
    Start up the motion tracker/stabilizer set it to stabilize the shot.
    Track a good point for as long as you can. Then alt-drag to a new point and track for as long as it works, then alt-drag, etc. etc.
    Once you finish that, apply it.
    Then just animate the move you want. You will have to scale it up a bit to compensate for the stabilization.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Chris Wright
    January 28, 2012 at 1:21 am
    if you set the final output comp(it was 23.976 in my example) to the same fps as the rest of the comps(29.97), it will smooth out your pan.
    https://www.mediafire.com/?4gbid2d11877b1p
  • Jason Creetee
    January 28, 2012 at 2:58 pm
    You are the man!Saved my flight back to the west coast!
  • Jason Creetee
    January 28, 2012 at 4:28 pm
    Thank Michael,
    I tried the stabilize motion and track motion. The situation now is the movie is panning in a horizontal plane and the movie needs to “speed up” a little bit sometimes and needs to ” slow down” a little bit sometimes in order to make the panning look smooth and professional. Is there any setting in the motion tracking panel? thank you.
  • Michael Szalapski
    January 30, 2012 at 2:13 pm
    Are you talking about the speed at which the footage plays back or the apparent speed of the camera move?
    – The Great Szalam
