Activity Forums Maxon Cinema 4D smooth transition between objects
  • smooth transition between objects
    Posted by Bruce Rudolph on April 10, 2010 at 9:10 pm
    Im trying to do a smooth transition between one object and another.
    In this case I have a bunch of cloned cubes in the shape of a dollar sign. (object mode, volume)
    Im animating a random cloner to scatter the clones and then bring them back together in the shape of a euro sign. (see attached project file)
    Is there a way to do this without getting a “Jump” in the clones position when the object changes?
    ultimately, Id like to create something like the pblurp effect only with cubes as the transition shape.
    I think you can do this with TP, but I have yet to crack that nut and I have a deadline coming.
    Any ideas????
    697_objecttransition1.c4d.zip
    Bruce Rudolph replied 16 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    April 11, 2010 at 3:45 am
    You can do it, but not by animating the cloner’s object parameter. Instead, do this:
    * create a mograph matrix object with the same parameters as the cloner, except referencing the euro object instead of the dollar object;
    * create/apply an inheritance effector to the cloner;
    * set the inheritance mode to “direct”, drag the matrix object into the object slot, and check the “morph motion object” box;
    * keyframe the inheritance effector’s strength to move the clones onto the matrix particles, forming the euro shape.
  • Bruce Rudolph
    April 11, 2010 at 8:59 pm
    Thank you Adam, some how a use the inheritance effector all the time and never use the clone function. Really cool.
    Cheers
