Activity Forums Adobe After Effects Smooth transition between keyframes
  • Smooth transition between keyframes
    Posted by Rolando Banks on October 13, 2017 at 2:58 pm
    I have fastIn-slow-fastOut movement. And for smooth of this i need to make keyframes Ease In and Ease Out and then compare Keyframe Velocity to make smooth speed without stops. So i have something like this:
    What is the best way to make this? Do you know better ways to achieve smooth movement in this situation?
    Rolando Banks replied 8 years, 11 months ago 2 Members · 3 Replies
  • Rolando Banks
    October 14, 2017 at 12:23 am
    No, i don’t need to hold same position between 2 movements. I need smooth speed changing between keyframes.
  • Greg Gesch
    October 14, 2017 at 12:56 am
    Hi Rolando. Select all your keyframes, right click on one of them and select “Rove Across Time” from the selection window that appears. This will give you smooth, continuous movement from the first keyframe to the last. I think that’s what you want.
  • Rolando Banks
    October 16, 2017 at 5:21 pm
    Nope. I’m talking about situations like this:
    I solve it by Keyframe Velocity where i just write equal values:
    But i want to hear other methods, maybe better than my.
