Activity › Forums › Avid Media Composer › smooth slow motion
smooth slow motion
Posted by Abra Kadabra on November 25, 2007 at 11:41 amis there anyway to make a slow motion smoother?
maybe like applying some frame blending or something?Grinner Hester replied 18 years, 10 months ago 3 Members · 4 Replies -
Bouke Vahl
November 25, 2007 at 4:10 pmToy with Effects – > time warp and select ‘blended interpolated’
Works like a charm.
Have a look at this short demo:
https://www.editb.nl/serge/speedramp.wmvAfter about 30 seconds there are some shots done that way.
Bouke
http://www.videoToolShed.com
smart tools for video pro’s -
Abra Kadabra
November 25, 2007 at 8:20 pmthe problem is when i use blended interpolated the picture becomes jumpy. it jumps up and down.
it happens when i use blended interpolated or interpolated but not when i use both or duplicated?
any idea why? -
Bouke Vahl
November 26, 2007 at 9:57 amsounds like a field dominance problem… Does not happen here, using all upper field workflow.
Is this a normal ingested clip, or an imported render?
And, are you rendering to the same codec as the master clip?(mixing DV and other codecs, at least in Pal world, leads to mixed field dominance on output, even if you mixdown. Output to video is always good however)
Bouke
Grinner Hester
November 27, 2007 at 3:47 pmI have good luck with fluid motion most of the time. Every now and again, it pops a frame it’s trying to morph but it’s always easy to fix. Slow renders but a good opportunity to surf the cow on the clock.
