Activity Forums VEGAS Pro Smooth Slow Motion Fade In/Out
  • Smooth Slow Motion Fade In/Out
    Posted by Damian Last on December 21, 2008 at 11:02 pm
    https://www.youtube.com/watch?v=J_F8MiNXt-M
    I wanted to do this effect using the velocity envelope , bot id dosen’t affect the audio.
    The guy who did it told me tu cut the clip into million pieces ,and then slowing down every single clip by holding CTRL and streaching it
    i don’t have time to doo so much things for a simple effect like that…
    So is there a way or plugin , to make a slomotion-curve for the video and audio ?
    If not tell me what other video program i can use to make such an effect.
    Ernie Tamminga replied 17 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Craig Patterson
    December 22, 2008 at 2:48 pm
    There’s a nifty VST plug for audio called Tapestop, found here:
    https://hem.bredband.net/tbtaudio/archive/files/Tapestop_1-7.zip
    You’ll need to automate it twice – once for the slowdown, and once for the speedup.
    Craig
  • Damian Last
    December 22, 2008 at 6:16 pm
    it dosen’t work
    ive copied the dll in every plugin direcotry …
    and it dosen’t appear in VST folder.
  • Craig Patterson
    December 29, 2008 at 3:06 pm
    First of all, I hadn’t noticed that you need a velocity envelope for the video as well. Vegas has velocity envelopes, unless you’re using Movie Studio, in which case you’ll want to upgrade to Pro to get the effect you’re looking for.
    As far as Tapestop goes, there is only one folder that Vegas will be looking in for VSTs, so I’m not sure why you say you’ve put it in “every” folder. If you put it in the correct folder, it will appear as an audio effect. It will never appear as a video effect. Look under Options..Preferences..VST Effects to find the folder Vegas will be looking in.
    Craig
  • Ernie Tamminga
    February 5, 2009 at 9:27 pm
    Cool plugin – thanks for the link.
    I can hear its effect in realtime, when I engage it while playing an audio clip on the Vegas timeline. But I can’t figure out how to SAVE the slowed-down/sped-up audio. No clue in the readme file that comes with the plugin, unless I’m just missing something…
  • Ernie Tamminga
    February 5, 2009 at 9:29 pm
    I can hear its effect in realtime, when I engage it while playing an audio clip on the Sony timeline. But I can’t figure out how to SAVE the slowed-down/sped-up audio. No clue in the readme file that comes with the plugin, unless I’m just missing something…
  • Mike Kujbida
    February 5, 2009 at 11:21 pm
    Just like any other FX, you have to render it to save it.
    Render either just that audio track or the entire video.
  • Ernie Tamminga
    February 6, 2009 at 12:33 am
    Ah, should’ve mentioned in my first post that I did, indeed, render the clip to a separate WAV file — but that file turned out to be “empty” (silence), even though in real-time preview I do hear the slowing-down effect.
